1 - 11 of 11 Posts
· Premium Member
does it do it if you don't take anything out? raise back up if you put something in ? just kidding, it's common on the 400 do a search on seat struts and you will get your ansewrwererrewwerrr
0.37$ mini spring clamp from Hone depot fixed my problem.
I have both handy in my trunk, a prop and a clamp, both work equally as well.
The prop can also double as a throw toy for my dog where as the clamp can't. :D
Chappy,
I was having the same problem with the seat lift on my Burg 400. I saw a thread on this forum about how to order & install a new lift that works much better than the OEM unit.
Unfortunately, with this redesigned site, I cannot find that thread. But I purchased my new lift from Lift Support Depot.com and installed it with the help of a friend. The total cost to me (including shipping & tax) was $25.79, and it was well worth it. No more need for dowels or clamps and the seat actually goes up by itself now.
The Code# was 10596E32 and the other number is 4142E32/10596E32 so that you order the lift with the correct 8mm eyelet fittings on the ends of the new hydraulic lift.
The lower nut can be tricky to remove & re-install so be extra careful with it. I suggest that you call them and make sure they know what it's for because they've now had several orders from our forum members.
I think the original post was by Jeff MDR on Jan14, 2012. Good luck!
Problem solved: I just place my helmet at the front of the seat after I raise it................!!! So simple, too!!
· Premium Member
Chappy,
Unfortunately, with this redesigned site, I cannot find that thread. Snipped ..
Actually it is very much easier to search on this forum compared to the old. The reason for that - if you look at the top right hand side, there is an embedded google search facility which is much more powerful than what we had before.
I am struggling with the new software in the sense that it is unfamiliar to me - give it a year and we will all be used to it.
Norm,
Thank you for your comment. You are absolutely right - I had not tried to search for the thread via the new search feature. I incorrectly assumed that it would be like the old method which often caused me difficulty in finding the info I was seeking.
1 - 11 of 11 Posts
