1 - 5 of 5 Posts
I am trying to remove the seat butt rest from the seat, but the dang screws are holding the legs in and I have to remove the screws, but no luck. I want to make a back rest from that butt rest. Anyone solve this problem ?
Thanks, Jay.
Thank Mitch for all this information.
Reactions: DarisPakar
Thanks, Uncle Fester. I tried this but the screw is so tight it won't budge, and I don't want to strip the head. Anything else I can try?
You will minimize the odds of stripping the screw if you use a proper JIT standard tool. It's a good idea to have a set of these for working on Japanese bikes or else you risk stripping screws at every turn...so to speak. The reality is that you might strip the screw at the threads even if you don't strip the head; this happens often with those little butt rest screws. All they do is prevent the butt rest from coming completely out if you accidentally pull it too far. They're kinda useless, because you can always just stick it back in with no problems.
When I took those screws out, one of them did, indeed, get stripped on the threads. I used a dremel to decapitate the screw and tossed it. Never missed it a bit.
BTW, I'm selling my 3BrothersPerformance butt rest riser in the classifieds section.
Thanks, dogboy. One screw came out, the other is still not budging. I applied some 3in1 oil and will get back to it later.
1 - 5 of 5 Posts
