I installed the Saeng Wing-Tip http://www.saeng.com/2117.htm and have placed my review in the Product Review section of the Official Reviews category on this board.
Thanks for the product review. Unfortunately all windshield solutions work better or worse depending on the rider's height.chuck807 said:I installed the Saeng Wing-Tip http://www.saeng.com/2117.htm and have placed my review in the Product Review section of the Official Reviews category on this board.
Actually I'm going to see if I can have my mechanic see if he can either cut it down 2 inches or figure out some other way of lowering it 2 inches.pauljo said:Thanks for the product review. Unfortunately all windshield solutions work better or worse depending on the rider's height.chuck807 said:I installed the Saeng Wing-Tip http://www.saeng.com/2117.htm and have placed my review in the Product Review section of the Official Reviews category on this board.
Just a thought. If you tried one of those air cushions that folks have been discussing in another thread, it might raise you up an inch or so. That may or may not be enough to get you looking over the top - but that Walmart one is only $10 - cheap enough to experiment with...
Or... You could return it to SAENG, and request the Winglet - which is basically the same as the Wingtip, but much shorter... The mounts might even be the same, so you wouldn't have to remove the ones already attached to your screen. Call Nancy and ask - it might be a great solution (and the Winglet is less expensive too).chuck807 said:Actually I'm going to see if I can have my mechanic see if he can either cut it down 2 inches or figure out some other way of lowering it 2 inches.
Its the stock windshield. I'm 5'10" and the Wing Tip was too tall for me (I like to look OVER the Wing Tip, not through it)... so I turned it upside down and its perfect. Now instead of 6" above the stock windshield (or whatever the height was), its only 2" above. The adjustability is still there and well worth it. If I ever sell the bike to a taller rider, I can just flip the Wing Tip back to "normal". Being able to adjust on the fly is priceless! Wind in my face during sweltering heat, and no wind at all when cold out, and any combination in between.seatec said:Chuck is that the stock windshield you put the wingtips on, how tall are you :?: Wayne
