Thanks pauljo. This may work for me then because the stock windshield is about right for me. Just need to disperse the wind a little more. Since I ride in all weather conditions, I am also interested in their claim that it will disperse rain more to the outside.pauljo said:Actually, I am using the SAENG Micro-Swirl edging with good results. It is designed a bit differently than the older "Stealth Edging" which I had tried last year, and it does seem to work better.
I've rode through a couple of showers on my way back from Scootercade. It has a channel in it that runs around the perimeter of the screen. This tends to catch any water that is moving toward the outside of the screen, and channel it down to the bottom. Be sure to buy a length long enough to completely go around the edge of your screen. I bought 5', and had to snip just several inches off with a pruning shear. I think can do with just 4' with the stock screen - but measure to be sure.30MuleTeam said:Thanks pauljo. This may work for me then because the stock windshield is about right for me. Just need to disperse the wind a little more. Since I ride in all weather conditions, I am also interested in their claim that it will disperse rain more to the outside.pauljo said:Actually, I am using the SAENG Micro-Swirl edging with good results. It is designed a bit differently than the older "Stealth Edging" which I had tried last year, and it does seem to work better.
Have you tried it in the rain?
It can be removed and reinstalled several times. It does not attach with adhesive. It has a thin metal channel that runs along the length of the edging under the rubber and grips the windscreen. After a few installations, the metal channel tends to spread some and lose its grip - if it is only in one or two places you can sometimes squeeze it back a bit with a pair of pliers (this usually will occur at the very ends of the edging first). I wouldn't recommend going beyond three installations.seatec said:Paul, when the micro swirl edge is put on can it be removed, I would like to try it, then cut my windshield down as much as possible and try it on again. Can you get extra adhesive tape with it to use it more than once. Wayne
