Would tapping into the 12-volt accessory socket in the glove box work?xenz said:... now all I have to do is to figure out where I can get a 5W constant power lead.
Yes but they won't work when the key is in the "parking" position like the rears do. That is why I wired them to the rear circuit.Brian said:Would tapping into the 12-volt accessory socket in the glove box work?
Thankyou ! Thankyou ! Much appreciated :thumbright:MJR said:Yes it looks like you can pickup the feed directly from the ignition switch at the brown wire coming from the ignition switch. I might rewire it later this way.
