I have to say first and foremost a heartfelt thanks for RedBeards installation guide. http://burgmanusa.com/bkb/tiki-index.php?page=650+Rostra+Cruise+Control :book:
A buddy of mine and I installed my Rostra cruise control using this guide and I can't say enough about how well the install went and nice this addition to my 650 has been.
I soldered and heatshrunk all electrical connections as well as modifying the cruise control handlebar box as per RedBeards instructions and it has been faultless in operation. I have run it on two test runs, one of 260 miles and one of 200 miles and it really holds the speed set well.
All I can say is it really is spoiling me, gotta be the best $230 I've spent yet.:D
Greg
Congrats. Sounds like a great addition to your Burgman.
Hello greginnm:
I have bought the bits and pieces, and I am trying to line up the time to tackle the install. One quick question: how did you install the switch? I have the switch that Redbeard modified (#250-392) but I am not sure yet where/how to install it.
Thanks!
Marco
Marco, I fabbed up my mounting plate using 1/8 aluminum sheet cut into a strip 5 1/2" X 1 3/8" ( 120mm X 35mm). I then bent it into a isosceles triangle shape so that the switch would be facing more towards my thumb than along side the plastic handlebar cover. I drilled mounting holes in the long side of the triangle to mount the switch and then drilled two 1/4" (6mm) holes in the upper back side of the triangle to mount the aluminum switch mount using 6mm push pin connectors. I also drilled a 9/32" hole on the back side to allow the sires to run through the mounting plate and into the handlebar cover. I drilled two 1/4" holes in the upper handlebar cover to attach the mounting plate. The 1/4" holes were drilled so that the switch was centered vertically and along side the powerswitch and the manual automatic switch.
I had to grind a notch into the lower handlebar cover to allow the wires from the switch to pas through to inside the handlebar covers.
I haven't figured out how to post pictures but if you PM me with your email address I'd be happy to send you pictures of my mounting system.
Greg
Glad to hear the install went well :D :cool:
This thing is spoiling the fire outta me, I love the cruise control!!!!:toothy5:
Thanks again for the really nice write up on the install.
Greg
