I have just serviced my K8 400 with 31k. The variator moving plate was clogged and all the rollers had flat spots.
After fully cleaning I installed some new non oem 26x13 17.5g rollers. The 5 pad clutch still had plenty of thickness and the belt looked ok, however I did not have a digital vernier to check the thickness. (One now on order).
On re assembly at tick over there is now the dreaded roller rattle which is fairly loud and It disappears at 2000+ rpm. The bike pulls and works excellent so there are no real mechanical problems, just the loud clatter at tick over.
I stripped it again and re checked? I reinstalled the old rollers and they now also rattle? I put the new rollers back in.
Why prior to the service was there no loud roller rattle?
Could the nut not to the correct torque be doing this as I used a 12v Impact gun? Done 150 mile and ok.
Could the belt even though looking good be over worn and below width spec? I'm to believe its 24.1mm minimum from a new 26mm?
Could the rear of the movable plate where the rollers sit be over worn?
I know the benefits of the DP sliders but would they be better, purely for to eliminate the rattle?
I recently met a chap with a 250 scooter and he said he had the exact same symptom but his was even louder than mine. He took it to a mechanic and they said 'They all do that, after fitting new rollers, and will get better after a few thousand miles!' Could this be for the dust to build up again and dampen the rollers?
I have read one post where fitting a new belt cured the rattle? Could this be the belt being wider pushing the movable plate further in by say 1-2mm, thus making the rear plate tighter against the rollers?
I'm living with it but annoying. Just waiting for the digital vernier to check the belt before possibly having to order a new one, the oem belt is £160 ($240)! But Malossi Kevlar is £90 ($135).
Your advice and tips would be appreciated. Thanks, Colin
