So after installing the 2 bearings in the clutch I decided to remove the bearing from the clutch cover and repack it with grease.
‘there are 2 Phillips screws holding down 2 clips to keep the bearing in place. Those 2 screws are frozen in place.
‘Now keep in mind, you can’t get rough with this process as that metal cover “although strong” is so fragil in many ways. I do have a hammer impact. You know, you put it on the screw and hit it while the blow of the hammer ratchets it loose (you hope).
‘I’m certain this cover is too fragile for this. I flipped the cover over and the screw holes go the whole way thru, so I put some panther piss in there and heated with my little torch. No good….. I have the screw holes full of lubricant soaking. Not sure what else I can do. Right now I could put some grease on that bearing but it would not be like packing it. I can then put the cover back on bearing. I really don’t want to cut the clips holding down this bearing. You can see in the pics, this bearing needs packed.
Any ideas will be appreciated.
