1 - 5 of 5 Posts
· Premium Member
I haven't yet tried; I want to move the passenger backrest from my broken 2007 to my current 2007. I saw the "How To" on installing but I'm unsure of where to start on removal.
· Premium Member
? My 2008 doesn't have a stock passenger backrest. Like to help you but can't. Do you have a photo?
If it's an OEM backrest, start by removing the pad .
Work your fingers under the lower edge of the pad and gently but firmly pull outwards.
There are 2 pressure fittings that hold the backrest in place.
There's either another another pressure fitting at top, or slide upwards to release.
You can now get to the mounting hardware.
· Premium Member
Discussion Starter · #4 ·
That's the direction I needed. Took less than 20 mins. Thank you.
Thanks for checking in.
Thanks for the information Jim. The same procedure works for my 2010, 400 LTD.
1 - 5 of 5 Posts
