Hi, All. Just been changing out the rear tyre. I have only had the Burgman a couple of months, and noticed that the rear tyre was very old and hard! 11 Year's old to be precise.
I doubt in that time the wheel has been off. Removal was okay until it came to dislodging the axle shaft spacers. The flanged, shorter spacer against the swingarm took one hell of an effort to remove, even with levering the swingarm. When removed, I swear the swingarm 'snapped shut' about 5mm or more!
Now, on refitting, I have the same problem. There's about 5 to 7 mm 'short' to get the spacer back in. I have levered the swingarm outwards as much as I dare with a 5 foot bar, even made a wedge out of some 4 x 2. No dice, it won't drop in between the long spacer and the swingarm.
Last thing I want to do is crack the swingarm, for obvious reasons!
The wheel drive system is fully engaged at the other side!
Any thoughts? I think the fact that the assembly has been left intact for several years has not helped. The bike is from Madrid and has lived in a warm climate all its life. ( And will continue to do so.)
I am loathed to grind down the spacer, as that will have an effect on the rear geometry as regards the brake caliper for sure. Not that I can't attend to that if needed.
