1 - 10 of 10 Posts
For the 650 Burgman, does it have a rev limiter that does not allow the rpm's to reach the redline on the tach. When in manual mine cuts out at 8000 rpm's, I was wondering if anyone else's did the same. Thanks...
I looked through the manual and found no mention of a rev limiter. The only reference that I found was in break in procedures and they say not to exceed 8500 rpms at any time.
Scutour said:
I don't believe there is any significant performance gain above 7k rpm on the AN650.
You right.
When dragging in the street- Hold front brake, start roll-on, release - dont have to spin rear tire, its just to get a little load on the tranny. Open throttle all the way...
If you are good, you will hit sencond gear on the nose..if not...no problem, it will cut out as you bang into second gear , quite a thrill. As the higher gears go by...not so much drama.
big fun.
I added Formula One pneumatic valve lifters to my 650. I'm redlined now at 14,000 rpm.
LOL
1 - 10 of 10 Posts
