1 - 3 of 3 Posts
It fits nearly flush into the socket, and has a thin, 6' coiled cable to the GPS. The door will close over it, though it sticks out a tiny bit because of the cable. I don't plan to do anything about that because I'll hardwire it soon. Works just fine.
Enercell Mini USB power adapter, model #2730448. $21.00 and change at Radio Shack.
I'll have to make a little mod on the mount, just trim away a little on the back. The Garmin cable has 90-degree plug where it goes into the GPS. That's covered by the backing plate. The Enercell cable is straight, so I'll trim away the backing with a Dremel. Should be a two-minute job.
1 - 3 of 3 Posts
