1 - 7 of 7 Posts
Does anyone know of a stereo made for the Burgman...or any radio that will conveniently fit. Somewhere I saw a radio tucked under the seat that had a remote . I presume that any radio with a remote will work, but where do you put the speakers so you can hear them. Any information would be appreciated.
A Fox
Bethesda MD
:) Hi, I installed a radio on my 650 like Lonnies with wired remote I also
installed 4inch speakers,made covers from 4 inch pvc pipe end caps,top
cover was made with 4 inch plastic drain covers. Primed and painted with
black plastic spray paint.Installed over grills on each side of dash cover.
Looks and sounds great.Bought speaker covers from Lowes.
Speakers
Hey guys ..remember if you install speakers over the vents ..that's where the mirrors fold into. So your mirrors won't fold !
Discussion Starter · #5 ·
stereo for burgman
[no1shoetack
New Member
Thanks for the reply. Do you have a picture? Sounds innovative and original
:) Foxy,I dont have a picture but I will take some and if you will e-mail me I'll send them to you. [email protected]
See photos of my radio setup at:
http://autos.groups.yahoo.com/group/burgmanAN650/
See PHOTOS and select AM-FM-MP3-CB folder
Pyramid Sound Corp makes the waterproof 100 watt 4 inch
speakers ( with grill ) that fits my radio shelf perfectly. I painted
them black to match the bike, and mounted them to the radio shelf
with a U-Bracket, made from aluminum bar stock. The U-Bracket is
screwed to the plastic magnet enclosure with tiny wood screws. Inexpensive waterproof speakers are extremely hard to find.
Photos of this speaker are located at:
http://www.pyramidcaraudio.com/itempage.asp?model=MDC6
JC Whitney carries these speakers for $19.99 ( 2 speakers in a box )
catalog number 37-9346N. These speakers are NOT in the JC Whithey on-
line catalog, and must be ordered via telephone order.
http://www.jcwmotorcycle.com
>The Radio Shelf consists of a standard aluminum bar stock 1 1/2
> inches wide, which spans the handlebars just in front of the
> hydraulic brake cups, and is held in place by velcro AND zip-
> ties. The last 1 inch of the bar stock is slightly bent and cut to
> clear the brake fluid cups. A hole is drilled at each end of the
> shelf for a 11 inch zip-tie to wrap around the handlebars. This bar
> has plenty of space left to mount a GPS and radar detector.
> I built a container for the car radio with aluminum angle stock and
> aluminum sheet metal, and held together with pop-rivets. Any
standard
> size car radio fits neatly between the handlebars. The radio
> enclosure is mounted to the 1 1/2 inch shelf with hinges. Hinges
allow
> the radio to be raised to get at the wiring. Hinges are pop riveted
> to the shelf and to the radio housing.
> The wiring harness shown in the photo contains speaker wires, +12
> Volts Battery from the cooling fan fuse, accessory power and ground
> from the behind the cigar lighter socket. Wiring harness also
> contains the CB antenna wire which is routed down behind the front
> wheel splash guard and under the bike to the rear mounted CB
antenna.
> The CB radio mounts under the AM-FM-MP3 radio via aluminum angle
> stock pop riveted to the radio housing.
>The Maxim 40 channel 5 watt CB was purchased at WalMart for $29,
> and the AM-FM-MP3 is a Panasonic #CQ-DFX683U obtained from Circuit
> City for $189. This radio plays both CD-R and CD-RW CD's equally
> well. Each CD plays approx 10 hours of music.
> The setup works extremely well during my testing, and the waterproof
> speakers were easily heard at highway speeds with my
> helmet on. I was skeptical of the speakers at first, but they ended
> up working A-OK.
> Future expansion plans:
>hooking all of this up to an intercom. I just ordered the MOTOCOMM >Audio Boss intercom system from
http://www.alfenterprises.com/motorcyle ... adsets.htm
Fred
1 - 7 of 7 Posts
