At first I thought taking the fairings off my Burgman was going to be a pain. After doing it a few times I came to like those Push Pins, they realy do work easy and hold good. In fact so far everything I have worked on so far is put together with mostly Push Pins and a couple of different size screws maybe a allen screw or nut here and there. Some of the plastic parts are snaped together then held tight with a push pin. Figgering out which way to unsnap the parts is some times a little frustrating but once you find out which way to put pressure on the part they usualy pop off. The only problem I have had is I broke one push pin, it was a med. size one, there are about three different sizes. My queation is where can a assortment of these puh pins be purchased at a resonable price.
Terry in AZ.
Terry in AZ.
