What kind of coolant do you guys (and gals) prefer to use? I'm at 16K and need to do some maintenance.
I also use Prestone but I use the premix. Can't see buying a gallon of antifreeze and a gallon of distilled water then only using about a quart and a half of mixed solution.
I use Engine Ice. I do a lot of track days, so I always have a few quarts in my garage, so it ends up going in everything I own. Otherwise, I'd just buy the premixed stuff from the dealer. If you like puttering and want to mix your own, go for it. Because my time is limited, I prefer the 'buy and go' solutions.
That. Plenty of tap water is totally unsuited for using to mix coolant!
