Don't know if they have a spray type cleaner. I have the Plexus product and it came in a plastic bottle that is pored like liquid wax. I would personally use Johnson Pledge as it is very effective in cleaning and shinning anything on the bike without leaving any residue.tomfelock said:Nolan recommends Plexus to clean the face shield with. Does anyone know if Plexus comes in a pump type container, since spray containers sometimes lose the gas/whatever and one can't get the rest of the product out?
I have had this problem too. It's not the gas that runs out it's the spray nozzle that clogs. I just switch nozzles from a new can.tomfelock said:Nolan recommends Plexus to clean the face shield with. Does anyone know if Plexus comes in a pump type container, since spray containers sometimes lose the gas/whatever and one can't get the rest of the product out?
there is a solution to that, as you finish using the product, turn the can upside down for a short time , the propellant will continue to come out, clearing the nozzle from the inside and no more clogs, how this can be accomplished on the new all angle spray paint cans I have no idea , for now I just set them down beside a sleeping cat and shoot them (the can, ) with a .22 as I know the nozzle will be clogged and the can useless next timeMarv said:I have had this problem too. It's not the gas that runs out it's the spray nozzle that clogs. I just switch nozzles from a new can.tomfelock said:Nolan recommends Plexus to clean the face shield with. Does anyone know if Plexus comes in a pump type container, since spray containers sometimes lose the gas/whatever and one can't get the rest of the product out?
I've used Pledge on Nolan helmets and faceshields for about 6 years now with no problems at all. Most of the folks I ride with also use it. Robin uses it on her Nolan helmet too and she rides more miles than I do.tomfelock said:When I called Nolan, I asked the person I spoke to if Pledge was ok to use and his answer was that it was NOT ok. If any of u have used Pledge for a significant amount of time and have had no problems using it, please let me know since what works well in the "real" world is all that matters to me. Thanx!!!!!!!!!!!!!!
