1 - 2 of 2 Posts
I've read a few discussions of using high beams during daylight driving to make yourself more visable. If you do use high beams during the day, do not expect the passing lights to function although the passing button should turn on both high and low beams. When the high beams are on, the passing button does nothing. If you have the passing button pressed and then turn on high beams, you will see the low beams cut off.
1 - 2 of 2 Posts
