1 - 9 of 9 Posts
I notice that my passenger seat padding keeps coming loose?
Does this happen to anyone else? Any ideas?
On the backrest or seat itself?
I've never had a problem with the seat itself but one of the grommets on the backrest was not seated 100% in the hole and I need to take it apart and re-set it.
Never heard of that one before - can you post a picture in the gallery?
The padding on the passenger backrest being loose is very common. I've had to press mine back in place a couple of times.
Next time try a little spray glue before pushing it back in place. :wink:
I use a spray glue because it is sticky enough to hold, but can still be taken apart. :)
I was thinking spray glue.
I've never really modified anything in my life that was new or expensive...I don't want to mess anything up. Thanks gang.
I had that problem with mine, but then I figured it out. If it's coming loose it is not in right. You have to take it completly off and then you can see that there is one part of it that is not in place. Once I figured that out and put it in right it does not come loose. In fact you can't pull it loose now and before I could. Hope this helps
I had similiar problem, I found that one of the plastic pegs that fit into the rubber escutcheon had broken and was missing. Further the retaining screw for the bottom of the seat back was also missing. Nothing I could do about the missing peg, but resetting it and then replacing the missing retention screw made a difference--now its not loose!--Dan
1 - 9 of 9 Posts
