1 - 12 of 12 Posts
I have mentioned this on the UK's Suzi' owners club site but they thought I was on some chemical stimulant!!!! :D Motorcycles not having a parking brake.
Has anyone had the parking lever end fall off their Burger :?:
I did. I reported it to Suzuki as I thought it was a poor engineering fault that allowed it to occur. In so far as, the end cap is held in place by a small screw. When, as in my case the screw fell out, top to bottom enabling the end cap to fall off. I put it to Suzuki UK that the part would benifit by the locating screw being inserted from the top. Thereby if the screw becomes loose it will not fall out and the end cap should remain in -place. Hope that makes sense.
I would be interested to know if anyone else has had a similar experience. I have actually made this part of a weekly maintenance routine, check tightening the screw.
doug
Mine has never fallen out, but I can see how it could and agree with your sensible suggestion to Suzuki - but I think the handle is different on the later Burgers?
The business end of the parking brake works absolutely fine but does need adjusting, say, every couple of months.
Welcome to the BurgmanUSA forums rodjunor. Glad to have you join us.
Welcome to the BurgmanUSA forums rodjunor. :hello2: Look forward to hearing more of you - I can see you are big on irony - I like that!
Unfortunately with any bike, useage and vibration may cause fastners to come loose, hence the requirement to check fastners at service intervals,at least . Randy has the right suggestion a wee drop of thread lok will avert a repeat!
My wife isn't.
Have to do my own shirts. :wink:
1 - 12 of 12 Posts
