1 - 7 of 7 Posts
I took off the Pair Reed Valve which was completely and utterly cake with carbon and soot.
Cleaned thoroughly with alcohol...
BIG Question....
When I unscrewed the tiny screws holding the two metal plates(?) to clean both sides... I can't figure out which side the flat metal piece connects to on the rubber part...
One side has a small metal riser (tab) and the other makes the flat metal sit flush...
Which side does the flat metal lay on? One with the small round metal protusion so it rises up slightly or is it flush ..
Thanks
PAIR VALVE Hose routing? I think I solved my first question...have it right in picture...
But from the PAIR Valve...could anyone verify where that hose connects on the round cylinder ...is the PAIR hose on top or below the other hose......Thanks
The hose to the PAIR valve is the top one.
1 - 7 of 7 Posts
