Can anyone tell me if the yellow & blue paint marks on the Variator center nut and washer are from the factory? If they are, I have read comments here stating that the washer needs to placed correctly so as to apply the appropriate torque pressure on the fixed variator drive; that its a spring washer and therefore needs to have the elevated side facing towards you. Now once the washer has been "crushed" at 76 lbs per foot against the pulley, should it not be placed on the same way, WITH THE PAINT MARKINGS FACING YOU??? regardless of the convex/concave inclination?
