I have been using this Old timer tip for years.
I have used it for Many Many things.
1st I use a Fuel system cleaner and lubricant, same thing also is a top end engine Lube.
Engine seems smoother while running i have yet to do a fuel MPG comparison.
I used to use, Lucus, MMO, Star, Star actually works the best out of those three.
But None of them work like the Old timer tip, what works the Best is ATF dexIII, cheapest is fine, in the gas tank at least every other tank.
This will clean & lube Fuel Pump, Injectors, rings, valves, pistons, also lube the fuel system steel parts to keep them from rusting.
The ethanol fuel collects water very quickly, then Rusts everything in a really bad way, ATF lubes to avoid this problem.
My bike has a more noticeable smoothness to it.
I put in 6 ounces of ATF (Automatic Transmission Fluid) in the gas tank every other tank.
It is also good for storing the bike.
