I had never heard of it BUT...............
Wrench-Off Motorcycle & ATV Oil Filters
Premium Canister Oil Filters for Powersports
K&N Canister Oil Filters for Motorcycles and ATVs
K&N's premium line of motorcycle and ATV wrench-off canister oil filters were designed to meet the high performance needs of racers. These canister style premium oil filters are designed to handle high oil pressures and they can be used with the latest synthetic or semi-synthetic motor oils. K&N canister oil filters come with a 17mm nut welded to the top that makes removal easy. [ MORE ]
High flow rates, & outstanding filtration
17mm exposed nut for easy removal
Heavy duty canister construction
Traps 99% of harmful contaminants
Can be used with the latest synthetic motor oils
Drilled hole in nut for safety wire attachment
Premium Cartridge Oil Filters for Powersports
K&N Premium Cartridge Oil Filters for Motorcycles and ATVs K&N's line of premium cartridge oil filters for motorcycle and ATV applications provide outstanding oil filtration and protection. K&N cartridge style oil filters allow for a high flow-rate and they are ideal for modern synthetic motor oils.
Premium cartridge oil filters for motorcycles, ATV's and other powersports applications
High flow rates with outstanding oil filtration
Ideal for use with high-end synthetic motor oils
K&N Washable / Reusable Billet Oil Filters
Our Best and Highest Flowing Motorcycle & ATV Oil Filters
K&N's reusable oil filter will last the lifetime of your motorcycle or ATV under normal operating conditions. The filter housing, bypass valve and call plate are CNC machined from Billet 6061 T6 Aluminum. The filter cartridge uses stainless steel micro-screen and end caps bonded into a single piece for extra durability. The mechanical filtration is performed with dual woven T 304 stainless steel micro-screen that provides excellent engine protection while providing an increase in oil flow when compared to standard disposable oil filters. The filter cartridge contains two Neodymium magnets in the filter screens for additional capacity and debris removal. The seals are made with dependable long lasting mil-spec Viton for a dependability. The billet by-pass valve can be removed for cleaning and it uses a stainless steel sealing ball with a stainless steel spring for increased service life. A K&N Reusable Billet Oil Filter by Pure Power is truly the last oil filter you will ever need to buy for your motorcycle or ATV.
Billet Aluminum Housing
Stainless Steel Micro-Screen Filtration
Stainless Steel By-Pass Sealing Ball & Spring
Embedded Neodymium Magnets
Mil-spec Viton Seals
U.S. Pat. No. 7,413,089 and U.S. Pat. Pending
