Being without an owners manual for the moment I wonder if anyone knows how often to change oil on the Burgman . Also, what is the recommended oil? Does the transmission oil have to be changed as well and what kind of oil does the tranny take?
So Covert in your opinion how many bars should be showing on the temp gauge before I start my riding?Covert said:More important than all that, however, is properly warming the bike up before you take off on it- improper warmup is the Number 1 killer of engines. more than "improper" break-in or when you change your oil.
Covert,Covert said:...More important than all that, however, is properly warming the bike up before you take off on it- improper warmup is the Number 1 killer of engines. more than "improper" break-in or when you change your oil.
The oil change indicator will pop-up at 600mi. The dealer will reset it for you and it will pop-up up again at the next scheduled oil change (4k mi). If you did the service yourself, you will have to reset it yourself by holding down both buttons for at least 2 sec.... by toggling the buttons (i don't know which is which) you can then it at your desired interval - this info is detailed in the owner's manual :lol:Darex said:This question probably falls into the category of "duh", but will the oil change icon appear at 600 miles?
Do I have to then reset it so that it will know it was done, and then it will automatically reset until the next-recommended interval?
David
