Used the following procedure on both my AN650K3 and K7 and worked a charm... 1) With ignition key turned off, 2) Hold both the SELECT and RESET buttons in while, 3) Turn ON ignition key 4) After 2 seconds the indicator to change oil should extinguish 5) Release both the SELECT and RESET buttons.
