Thanks for the replay, it shows that it can be used front or back. It is a mitchelin pilot sport. I am worried about the size some what. It is a good tire though. The ratings are good.Buffalo said:Probably not. I did a quick search and could not find any 120/70-14 that was designed as a rear tire. All the ones I found were front tires.
Even if it is a rear tire you need to check the speed and weight rating codes on the side of the tire and see if it has enough capacity for the 650.
Are you sure about that. I went to the Michelin site and it shows the 120/70 14 Michelin Pilot Sport SC Radial to be a front only tire with a load rating of 55 and a speed rating of H. The speed rating is the same as the OEM rear tire but the weight rating is not. The 160/60 R14 has a load rating of 65. A 55 load rating is good for up to 481 lbs and a load rating 65 is good for up to 639 lbs.insp03 said:Thanks for the replay, it shows that it can be used front or back. It is a mitchelin pilot sport. I am worried about the size some what. It is a good tire though. The ratings are good.
