1 - 4 of 4 Posts
Want to install Magic Blinker for front flasher on burgie, to use this with current 12v bulb Suzuki supply, want to order with option of OEM turn signal blinker connector that manufacturer sell, not have knowledge on this type of thing/product, need help from other BUSA member for this, need to know type or model or make etc. of this connector on 650 so me can order Magic Blinker with correct connector from Custom LED so fit easy plug & play.
Thank you all for help,
http://www.customled.com/products/oem_c ... nector.htm
http://www.customled.com/products/magic ... linker.htm
· Administrator
I use two of these in my 08 650. I had to hand file off one of the studs to fit the Burgmans socket but it fits tight and does not turn out. http://www.superbrightleds.com/moreinfo ... oduct/527/
I installed the Magic Blinkers and had to hard wire in a LED flasher relay. The LED's will flash too fast without some Load resistors or a LED flasher relay.
I can not find my pictures that I took of my wiring. Its posted on the board somewhere back 1 year or so.
On my 03 I wired in some load resistors but found out they got real hot when setting an a red light with the turnsignal on. So I did the LED flasher relay mod and all was better.
With 2 Magic Blinkes, two LED bulbs and a flasher relay it costs close to $80 USD but the amount of forward visibility is well worth it. My lit up turnsignals cast a bright amber glow on the cars to my side.
You can re-read the topic here viewtopic.php?f=1&t=56925&hilit=Magic+Blinkers
· Premium Member
I ordered and installed the set from Kisan Electronics. I put one on my Burgie and one on my Honda VTX 1800. They work just fine and are fairly easy to install.
Flint
Discussion Starter · #4 ·
Flint
Me visit Kisan tech site they not have same product as Magic Blinker, I not need LED light or auto shut down, just want flasher on all time, but thank you for help.
1 - 4 of 4 Posts
