I bought a salvaged 2008 Burgman 400 and have enjoyed learning about it. My learning curve has been through trial and error trying to get it to start. I ordered a shop manual and the two relays that are the safeties for the fuel pump and the starting circuit. I also ordered a new tip over switch. I was able to jump out the safety for the starting circuit and the fuel pump circuit. Power is present for the safeties but the original relays got wet and have malfunctioned. The problem I am trying to figure out is in the starting circuit, so here is my question.. When I tested the coil, it checked good, but when I crank the engine over, the coil sparks only once then nothing. If I stop cranking, wait a few seconds and try again, I get one spark on the retry and then nothing. Before I jump in and start buying a new ICU, stator, pulse generator or other component, I thought I would ask the forum. There is 12 volts at the positive terminal on the coil, and I get a strong pulse on the 1st revolution of the crankshaft and then the remainder of the pulses are weak.
The bike looks as though it was kept covered but outside and shows signs of obvious neglect and moisture intrusion on some of the wiring terminal ends. I have checked, cleaned and rechecked. So what do you suppose the problem is with the ignition circuit? If anyone has ever had a similar issue, or experienced issues with weak or no spark, please jump in and offer your expertise.
Thanks guys
Roger, the new guy
Thanks guys
Roger, the new guy
