1 - 3 of 3 Posts
Hi Guys and gals.
I’m Mike from the UK, I have recently purchased ( a week before we went into lock down! A 2004/5 An650, it has approx 62K miles, with a lots of service history, I have just changed all of the brake discs, and refurbished the callipers. However a new fault has occurred today, after a fairly long ride.
In auto the bike pulls away, but the gears do not change, if I switch to manual, it will reluctantly change gear with numerous presses of the up button just to change one gear, if I switch back to Auto, the gears will decrease normally.
I think it could be one of the following:
1: the PPS sensor needs replacing $200 plus
2: the throttle sensor needs replacing. $170 plus
3: the left switch gear needs replacing. $30
I’m kind of hoping its 3, as this is cheap to do!
Any thoughts or theories would be gratefully received.
First guess..... NONE of the above.
Check to see if the CENTER stand plunger is extending out with the center stand in the up posistion. That is the #1 cause of your type issue.
Thanks Dave, however I should have qualified the fault, as it happens whilst the bike was in motion, slowing down for a roundabout, the pin is in the extended position on the switch, and it moves quite freely. I'll put this on another part of the forum.
1 - 3 of 3 Posts
