I am going to do my own 600 mile maint. I did the oil change last night. All I noticed on the oil filter was blue gasket seal residue. Guess that is normal. I went to do the final drive oil and could not figure out how to get the big black cover off. Do I need to take this off to change the fluid? Also is the final drive oil the same as the transmission oil? I did read that the final drive oil is 10w40. Do I need to change it now or wait until the book says like 4 0r 5k? Also where is the tranny breather tube you are supposed do dump fluid out of once and a while. I have had a few scooters in my time but none were this covered up by body panels. I can hardly see anything.
How do those body clips work. Do you pry out the center piece or get behind it an push from backside? Thanks for any help.
I am going to take it to the steeler next tues for the valve adj. They quoted me 85.00. How does that sound?
