No I was going to work battery is good , lights turn onFlat battery? Battery not charging.
Yes they are workingSo are you getting power? Are the lights working and the gauges operating? If so the would eliminate a dead battery or loose battery cable.
Yes , I think it's the switch to the side standWhen you turn the bike on you should here the fuel pump cycling up before starting. Do you still here that when turning the key to the on position?
Nope ,its the switch to the side standIs the engine spinning or nothing.
I'm glad it was something easy!
Pilots backside?sometimes kickin an whackin thangs is the answer(one type of aircraft I worked on in the military sometimes had to be kicked at a particular spot if it wouldn't start, then it started fine .
