1 - 16 of 16 Posts
give us a hint, does it have 2 cylinders or one ?
In USA for 2015 model year:
1 Small cylinder = Burgman UH200
1 Large cylinder = AN400
2 Small cylinder = AN650
3 Small cylinder = AN950
Reactions: s-steel
Gimme the AN950 , a quiet wife and the proverbial check in the mail in my hand...Please !
I merged the two posts.
Now the question 123Mike, Why do you need the starter removed? Maybe we can help see if its the starter or something else. Give us a clue as to what its doing or not doing.
OK, I do not think its the starter if it turns the engine over.
Try this and let us know what it does.
Hold the throttle wide open and then crank the starter over for a few seconds while holding the throttle open.
if it is the starter, they are quite expensive.
you can check first if the brushes are worn and get those specific parts. clean inside and lightly clean the commutator and rebuild. the other option is buy an asian one. I have. they are ok. dont know how long it would last. but I have an extra just in case because they are inexpensive.
up to you and I wish you success.
mikey was joking but it was a legit question as you left a critical tidbit missing in your post.
Discussion Starter #11
Thanks to all you guys for your help I did remove the starter opened it up and it was very corroded and sticky inside some of the parts were cracked I guess I will need a new one thanks a million and where can I get a aftermarket one I don't know the part number.
Dave_J, on the subject of starters. I’ve heard mine kinda slam a couple different times. Maybe I can do something to head off a future problem?
knowing this is a little old: are you sure the starter is not turning? it sure sounds like it is, in which case replacing it may not solve your problem. it almost sounds like this is an issue w/ the gears connecting the starter (e.g. loose pinion on starter; stripped gear teeth on pinion/wheel; etc).
btw: i dont even have my burgy yet, so this is all speculation based on other bikes.... :)
vince
Discussion Starter #15
Hey thanks Vincent 2:24 I've opened up the starter and one magnet was completely destroyed so I rebuilt it I got a new magnet put it in and I've been riding with the wind ev.er since thanks for your concern
1 - 16 of 16 Posts
