You can order them from Suzuki or one of the online parts suppliers. Part number is 47381-10G11-YHF for the grey. Unless you can manage to get the 650 emblem off your old door intact you will need one of those too. Part number 68131-10GA0. Both together are going to set you back about $50.
If what you broke are the tabs on the side with the holes that the hinge pins go through, have you considered making a replacement from metal. You could measure a piece long enough to bend up to form the tabs. Drill the holes in it then bend the two sides up. Grind the old tabs off the door but leave the center part where the spring attaches. Grind a notch in the metal piece to fit around the spring piece. Then bend a slight V in it so it will sit flat on the back of the door. Finally glue it on. Might save you a few bucks.
