My adapter plate from Bestem came in today. It appears to be of a good quality steel with a black powder coat. It has holes on it to mount a Bestem Tbox 2008, a Tbox 2012 and a Tbox 929. It also has holes to mount to a Burgman 400 or a Burgman 650 with the difference lying in the hardware that is shipped with it. Looks like a really good kit to me.
I have a 2009 Burgman 650 Executive that comes with the backrest. I googled how to remove my stock backrest and found instructions at http://www.max.grenkowitz.net/?topic=789. Taking the back-rest off is pretty straight forward. Just follow the instructions. Took me about 10 minutes. Imagine my surprise when I found all the necessary holes present in my tupperware after I removed my passenger back-rest. No removal of any tupperware needed. Nice.
I checked that the spacers fit in the pre-drilled holes that were there after I removed my passenger backrest. Yep, they fit just fine.
I stopped for the evening as the heat index at 7PM was 97 degrees and I have to remove the box and the stock mounting plate for my Tbox from my V-Strom. The stock steel mounting plate that came with my Tbox 929 is needed for this install and I was loosing light too as the sun was going down. It goes on over the adapter plate that I got this evening from Bestem. I will tackle removing the needed plate from the V-Strom and finishing the install on my Burgman in the morning if it's not raining.
I will continue with this thread after I finish up tomorrow.
Namaste'
Doug in Kentucky
Namaste'
Doug in Kentucky
