That thing is huge and hideous. There has to be a better option out there.One of the first radio packages was put together by Jac Vinson..
www.rvtoys.net
Look under products...he makes backrest brackets, & the
radio package is listed on the last page.
I've had one on my '05-400 since Aug.'05.
I guess I'm more lazy than you are...... I am way too lazy to transfer 4800 songs.. also not sure if I have the room on my smart phone for that. so I jsut use the Ipod with the splitter..
Since this came up again, my last variant was UClear earphones and a slightly different cheap Bluetooth receiver (two of them, rotated so one's charging while the other is in use). But I've since switched to a helmet that includes a Bluetooth comms system so I don't use that much any more.My current setup is a smartphone on a bracket that's strapped to the center of the handlebar cover. Bluetooth receiver plugged into a set of headphones I've cut the headband off of and velcroed to the inside of the helmet. It works, but the volume's a bit marginal. I use earbuds instead if I don't expect to be pressed for time.
