Ok, it’s time I posted a reply to my own question since I completed the installation of the Motolights today. I’m going to be as detailed as I can here since I didn’t go to school for it either. I do appreciate the responses I got even though they were not detailed enough to be of much help. (I even called Motolights and was referred to Mike (the Burgman expert who said “Why don’t you just let me do it”. To which I replied, “I’m in North Carolina and you’re in Florida, Duh!”) I used this link to Burgman 650 service manual (
http://ics07.ac.upc.edu/aramirez/lib/ex ... man650.pdf
My install was very simple. I did not want to switch the Motolights separate from the ignition. The motos come on just like the head lights. I began by removing the seat damper pin and then propping the seat as far forward as possible. Next, unseat the battery cover. Now remove the battery – negative lead from the battery and secure it away from the battery. You can now remove the rest of the leads attached to the battery cover and disconnect the hard wired connector. Now that the battery cover is out, remove the + positive lead to the battery and lift the battery out of bike. You can now disconnect the trunk light connector. Next, remove the 4 nuts holding the seat on. Remove the seat. Remove the maintenance cover. Now remove the 4 screws holding the trunk box. Remove the trunk box. Under the trunk box is all the space needed for the Motolights wiring harness. Place the fuse and relay in the fuse space on the left side. Run the light connector lead forward to the lower left where the oil filler cap is. Now install the lights to the lower caliper bolts on both sides of the bike and cable tie the leads neatly to the brake lines. They should exit the front wheel together on the left up at the hard brake line. Feed the connectors through the opening at the left of the radiator, into the space where the oil filler cap is. Cable tie the lines and the harness connector to the other wiring in this space to prevent stress on the connections. Connect the lines to the harness connector. Now, back under the trunk box I found a 4 wire connector and harness that runs back on the left side. These are the brake and tail light wires. I cut off the Motolights switch lead and scotch locked that lead to the gray wire in the tail light harness. (M y bike is 2012 Executive, others may differ). After a temporary battery re-connect to check the lights operation, I put it all back together in reverse order. Hope this helps someone.
Thanks again to everyone who responded.
