I purchased and installed the much hyped MotoBatt battery for my 400. Everything on the specs looked great and probably is if there wasn't an apparent flaw in there design imho. I had no problems the first 4 months and was very pleased with it but then it started to seem weak after it sat for 2-3 days. :roll: I thoroughly checked for electrical shorts or a current drain but found none. Now 8 months later it is finally too weak to hold a charge while eating breakfast at IHOP...just ask Bikeisback.
I checked about their warranty and they said to remove the sonic welded cover which has the date stamp on it and return it along with $15 blah blah for a replacement. So I struggled with removing the top cover feeling like it was about to shatter and send shrapnel everywhere and I found 6 rubber caps covering the cells underneath. I removed the caps and found each cell bone dry! :shock: Now this is not a dry cell battery and obviously won't hold a charge when dry it is merely a Glass Mat Sealed battery. I keep distilled water for my golf cart batteries maintenance and got a syringe to fill the MotoBatt up to what I would think would be the proper level. Each cell took 1 oz. of water...that's 6 oz. in that little tiny battery. :?
So my questions are:
How does a sealed system go dry?
Was this just an example of poor quality control or a design flaw?
Why would you sonic weld the cover on if it apparently needs maintenance?
Should i ask for a refund instead of a replacement?
I know another member here on this forum has posted "Maintenance" procedures he got from the manufacturer to bring the MotoBatt's back to life if it happens to you...Really?....on a sealed maintenance free battery?
I have since reinstalled my original 8 year old battery that has been sitting on the shelf and being used to jump off the MotoBatt weekly and never recharged and it cranked the 400 right up with no problem. :thumbup:
