My front brake feels softer at the lever than it should do. A quick bleed didn't improve things. Is this common? On a previous AN400X I got a braided hose made up by Harris but that didn't help much either.
Does anyone know if any of the Suzuki (or other) adjustable levers works on the K3 brake master cylinders? I'm pretty sure it's the same design as several other Suzukis.
Is the accessory socket in the dash glove compartment switched with the ignition? I'm thinking of adding heated grips and want to wire them into a supply that is switched.
Any thoughts on the best 3rd party windscreen for the AN400K3?
What bulb type are the headlight bulbs? H4? Are there likely to be any problems with heat or electrical drain from using standard car 55W/60W bulbs instead of 35W/35W?
