1 - 4 of 4 Posts
Hey Guys
have a problem going on with my left side mirror hit bumps in the road and mirror will not say were it should loosing the snugest in keep the mirror
were it should be so i can see
question is how do you tighten the mirror up to stay were you put it just the mirror now i know were to tighten the stem or rod
just need help on the mirror
thanks
SillyBilly :thumbup:
My left mirror was a little loose too where it attaches to the stem. I used some spray adhesive on the ball joint to make it hold tighter and it seems to work for me. Good Luck!
You'll need to gently tighten the nut and mirror into position first then back off the nut just a hair. Then hold the nut at the bottom of the stem with a wrench and gently move the mirror stem forward.
Strike that...that wasn't the info you wanted.
1 - 4 of 4 Posts
