The rear view mirrors are designed to give on impact and fold all the way inward (electically on the Exec, manually on the standard 650). I have not taken the mirror assembly apart but it feels like a soft "detent" is what locks the mirror in it's usual place. It is mainly designed to be folded backwards but also has give in it to move it slightly forward as well. From the looks of things I would guess that along with your slight damage to other components the mirror detent capability has also been damaged and will perhaps need to be worked on or replaced. Those mirrors are expensive and I suspect a dealer will want to replace the whole broken one but you may be able to fix it. Do some further research in this forum for help getting the mirror off and look for any U-Tube made by several of our hugely knowledgable members. The service manual may also be available online if you look for it and you can certainly purchase one from the net. If you keep your 650 you'll save a ton by using the resources available.
You have nothing to loose by trying to fix this yourself and a pocket full of cash if you're successful. Just tell yourself, "I'm not going to let a machine get the better of me", and Good Luck !!
Ride safe,
Pat
Ride safe,
Pat
