Hi
I have been investigating this.
Firstly you need to remove the tupperware, when you look at the rear of the bike you will see the fitments for a rack - they are really obvious. If you then look at the corresponding tupperware you will see they are premarked for drilling - so no problems there. If you have not taken the tupperware off before I would allow a total time of 2 hours, remove, drill, replace.
Givi also produce a rack which in UK is much cheaper than the Suzuki one. Of course you should investigate this for yourself. Here is an extract of the reply I received form Givi:
The part number for the rack is the Sr112 which retails at £49.50 plus vat. This limits you to the Monokey range of boxes we do. However, if you just want a small box with only a 3kg weight limit then the rack for that is the Sr113m which retails at £24.95 plus vat - you would then use the adaptor plate which we supply in the smaller boxes. Your dealer can sort this out for you.
Hope this is helpful to you.
