hello all,this morning I noticed that my end cap that fits on the the end of the throttle,was missing.I do remember having to keep tightening often.Guess I didn't do a very good job
So,where can I get one that is reasonable price????
John B
· Premium Member
You can get them at any Suzuki dealer but they will run you about $30. If you want cheaper than that then you are going to have to look for a used one or go to some kind of aftermarket design.
· Premium Member
I bought Manic Salamanders off EBay
a whole lot cheaper...they have an
expanding metal wedge inside that
doesn't come loose. Mine are polished
stainless steel...they have some colors too.
John B
Just tightening the bar end weights with a screwdriver is NO GOOD......!!! You need to use an impact driver to really snug them down...... Mine have never come loose.
Mines came loose a few times, you better go with the OEM stock the weight has to be the same the after market ones, may not be the right weight, the problem is to keep them dry as possible , No Lube or Oil, and will stay on.
Elliott,
