1 - 3 of 3 Posts
· Premium Member
If the bike is in limp mode you will have an FI indicator showing. The ECM will not go into limp mode without setting the FI indicator. You will need to find the code that is associated with that FI indicator then fix the problem that causes that code to be set. On the 650 there are over a dozen different things that can set codes and turn on the FI indicator.
1 - 3 of 3 Posts
