Hi All,
Well, finally done with the grips and cruise. All wired in and HOT! All was going according to plan, the throttle side went on perfectly, then the LH grip suddenly and PERMANENTLY stopped 1/8th" short of "home"
. The company provides genuine SuperGlue to affix the grips and as you are aware, you only have split seconds to get it right. Oh well, I'll get over it. It's not that noticeable. The grips utilize a 5 amp ATC fuse (it came with a micro fuse holder but I cut it out in order to utilize my installed fuse box). I bought some longer rear brake lever mount screws and with some 3/4" spacers passing through two holes drilled into the bar cover, the supplied controller mount bracket is very solidly mounted and "factory looking". You may notice the Vista Cruise installed as well. That required the throttle tube flange to be ground away. It works just as I remembered from my old 1974 Honda 750 days...perfectly!
Ed
Ed
