The Kisan SignalMinder has a brake imput option which stops the turn signal timer while the brake is applied. The other optional hook up is the running light option, both require finding brake and turn signal wires. This would require someone smarter than I. Has anybody preformed this ? This unit also comes with springs to modify the turn signal switch for non-latched operation. The simplest installation will automatically turn off the turn signals after 10, 20, or 30 flashes, which you pre set. Every time you use the turn signals, you have to still depress (cancel) the signal with the handle bar switch in order to use again. If everything was hooked up, you would have automatic cancelation, running light conversion, and brake override. My main concern was not having a car pull out in front of me because I had left the turn signal on. It would be great to have all features working----Anyone done this----Please help.
