1 - 1 of 1 Posts
Finally got around to cleaning up my accessory wiring with a Blue Sea 5025 Fuse Block. I had previously added running lights, voltage meter, usb outlet, but wanted room for future projects. I found out that by leaving off the cover, I could mount it and a relay in the locking glove box on my 2011 650 Exec. It's a tight fit, but I ran all the wiring down to it thru 2 holes in the top. I ran a new master power line of 12 gauge wire direct to the battery, and used a relay tucked in next to the fuse box. I used the wire from the 12 v outlet in the glove box to power the relay, and then wired the 12 v outlet into the fuse box. I also wired the switch for the running lights into the handlebar cover next to the voltage meter.
1 - 1 of 1 Posts
