1 - 12 of 12 Posts
Just wondering - can you jump start a Burgman using a battery tender cable's clamps? Does it work when attached to a car battery?
When my battery was acting up I used a dedicated jumper unit and it worked great. The one I used was just like this one.
http://www.sears.com/solar-900-peak...M7208425104?prdNo=16&blockNo=16&blockType=G16
I had to fit bolts into the clamp jaws to reach the battery terminals. I wouldn't recommend going through a tender's wires, they may not be able to handle the amperage. If the wires have a fuse then for sure they wouldn't as you would blow the fuse.
I don't think they are heavy enough. I think you would burn them up.
I built my own jumper cord...
basically an extension cord with
the polarized plug on one end
to match the Battery Tender
polarized plug, & a pair of alligator
clips on the other end..about 15 feet.
Used it twice so far....both times to
jump start a Harley at a funeral.
If you use a car to jump-start your
Burgman, the car does not need to
be running....we're only talking about
a 10/12 AmpHr battery in the Burg.
Just give it 5 minutes or so, then
crank it.
I'm not sure what the wire gauge of those clamps is so don't know if they will carry the load or not. The battery in your 400 is rated to produce 135 cold cranking amps. To handle that much current you are going to need at least 10 gauge wire and 8 gauge would be better. You might get by with lighter gauge if the bike fires right up but it you have to crank it for very long you could get into trouble.
DO NOT jump your Burger with a RUNNING car's battery. It will screw up the computer. It will take some starts and riding with a rough running engine to get it to stabilize again. Don't ask me how I know.
......and remember...I have dual batteries.
My intention with my 'jumper-cable' is only to
put an additional charge into the battery, so
the bike can crank on its own.
I've used that tactic to get a bike started with 14 gauge wires with alligator clips that I use for trouble shooting electrical problems. Had the wires in my top case and hooked them up to a friends bike battery from my bike battery. Let my bike run at 3,000 rpm for about 10 minutes to put some charge in his battery then he was able to get it started.
Pretty much what I did with the 2 Harleys...
I found this on Yamahas site. It measures 6x2-7/8 x1. 14oz.
It says it can jump start cars too.
Oops, lol, someone else before me already posted this one, about $50.00 cheaper too!
it takes little understanding of electronics to understand and cope with battery charging. But if you have it or are willing to learn this will do almost anything battery related. change/discharge/cycle/capacity test etc etc
http://www.hobbyking.com/hobbyking/store/__6792__iCharger_106B_plus_250W_6s_Balance_Charger.html
cheaper and do an awful lot of the above.
http://www.hobbyking.com/hobbyking/..._6_50W_6A_Balancer_Charger_w_Accessories.html
both will run on 12v so you just make up some cables and your off.
I have the iCharger 106b and I can do anything from one single aaa cell to a huge 12v deep cycle
EDIT: pardon me, I have the 206b and can charge at up to 20amp if I have a supply capable of providing it.
1 - 12 of 12 Posts
