So something interesting happened on a trip the other day. About an hour into it and while driving on the highway at about 65 mph actual in perfect weather, my instrument cluster went through what appeared to be 2 back-to-back power-on self-tests. You know, the ABS and FI lights went on, the speedo and tach did their full sweep, etc. It was exactly the same as if someone had turned the ignition on except that the engine never missed a beat and kept on running. When the self-test routines were finished, everything behaved normally except that the speedometer was off the scale. When I got to my destination, I shut the ignition off and noticed that the speedometer now reads 10 mph when the bike is stationary even when the ignition is off. The speedo still seems to function except that in addition to the "normal" error it is off by an additional 10 mph (so 65 actual is now something like 82 indicated).
Here's the weird part though...the ODO and MPG still reads as accurately as they did before the incident. This indicates to me that the sensor is still operating normally and it is just the speedo side of the cluster that is jacked up.
I've not done extensive troubleshooting on this yet. I have checked the connectors on both ends of the speedometer, disconnected and re-connected them. Unfortunately the problem persists.
Has anyone experienced or heard of anyone experiencing anything like this before?
