1 - 3 of 3 Posts
Here is an easy safe way to block the sun. Put a piece of black tape around the
BOTTOM of your shield. If the sun is blinding you simply raise the shield to provide
needed shade. Works great on any shield.
I put the strip at the top of mine. With some of my bikes I'm directly in the Windstream so I have to keep the shield closed when I'm moving. Either way it has proven to be a very useful safety feature.
You're right, being able to see is kind of important. The advantage of having the tape at the bottom of the shield is that you can block the sun by moving the shield up and down as needed. Unless you are traveling at warp speed with no windscreen a temporary lifting of the shield isn't a problem.
1 - 3 of 3 Posts
