Well,
I finally installed it.
I used these instructions as a guide: http://vstrom.info/htmls/topcase/topcase.htm
I had a bit of a problem I broke off one of the plastic hooks that secures the rear panel (taillight access) Be careful when removing.
I was able to knock the hole into the mount by hitting upward from under the mount for the top case.
If you don't own a case yet, I would highly sugesst spending the extra $$ for a prewired kit. It was a bit of a PITA to install not difficult but when the little rubber gasket keeps comming out and then the wires from the light kit kept separating at the connectors. I taped the wire down to the PCB and cut notches to secure the board into the lamp housing.
Also I would suggest using a 12V power sorce to test the lights prior to final install on the bike.
Ed
Ed
